Today I removed each wheel bolt, gave it a clean with steel wool and painted it with Hammerite silver paint. Certainly makes them look a bit smarter.
However on one wheel bolt the wheel wrench slipped and I removed a lump of paint from the alloy. I rubbed this down to expose bare metal so put a little bit of primer on and rubbed down again, then a healthy dose of clear lacquer. Its not perfect but I don't want it to get any worse.
The question is, will this be sufficient to avoid rust getting a hold? Should I do anything else to effect a decent repair?
Grateful for any comments.
