Would anyone be able to tell me if these fit my W211 E55.
Would I need spacers?
I have looked at the table from Alloywheelsdirect but could not find anything.
You should be ok with the front, but not too sure about the rear. There should not be any internal issues but....
Here are some 9.5 wide ET 33 rears on a 211 and it's close but not touching the arch. If you add the extra 6mm (rim width) and 5mm (extra offset) you may well be in touch condition! The tyres are 275/35/18
They would be fine on a CLS with wider bodywork, but I'm not sure you would want to make your bodywork wider!
Mactech thanks for your help.
I know the fronts will fit for sure its the rears I am worried about.
I currently have the same set up for as you have on your car with 9.5 on the rear, but just not really sure about 10 on the rear with that offset.
I suggest the minimum wheel to arch gap should be 10mm. If you can currently fit a 20mm dia (marker pen or similar) stick in the arch/wheel gap then the additional 10mm or so should be ok. Less than that and I would worry.
