Hi here is the install with photos!!
Wow for such a little unit, it was a bit of work putting in al the wiring :s
1.
Remove Head Unit and Glove Box and Door Sil.
2.
Remove Glove Box surround and passenger floor mat + carpet.
And plastic under the Glove Box.
3.
check all current wiring that was already in place :s (lots of it).
4.
Remove Rear Seats (both parts)
5.
Remove passenger side rear panel.
6.
Remove Bose Sub woofer.
7.
Start to locate Alpine Sat Nav wiring around the tunnels
from front to back.
8.
Feed wiring through rear metal panels into to boot area ready for connection.
9.
(DISCONNECT POWER).
Attach in new Nav wiring to the Head Unit and Ai-Net
Located GPS Arial in dashboard.
10.
Quick check over all wires to make sure they are correct.
Plug Head Unit and Sat Nav in. Attach power back.
11.
Power on Unit.
Test all settings and car operations are working correctly!
12.
All OK!
13.
Power off again, and locate in all new wiring,
all the way round to the boot
14.
DONE!
Now fit everything back together
(Reverse order).
fewwww thats done
works great love it!!
S.
1.
2.
3.
4.
5.
6.
7.
from front to back.
8.
9.
(DISCONNECT POWER).
10.
11.
Power on Unit.
12.
All OK!
13.
14.
DONE!
(Reverse order).
fewwww thats done
S.
