didi w203
Hi all, just joined so be gentle. Recently purchased a 52 plate 1.8 kompressor coupe. Esp error lighting up my dash. Did a scan with a snap on solus and launch x431 diagnostic and came up with 2 codes.
p2035 and p2036.
p2035 said brake light switch, now my brake lights work, and im sure esp error is combined to the switch.. Had a look at the brake pedal and there is no switch..then i had a look at my master cylinder and it has a sensor on it. I unplugged the sensor and brake lights still worked but now had a BAS error, plugged it back in BAS error gone. so where would the brake switch be located?
p2036 cruise control/speedtronic error. cruise control electronically turned off?
Again this could be due to esp error?
Any help appreciated. Thanks.
p2035 and p2036.
