Does it give any trouble turning in the ignition or starting the car?
There are various posts in the forum about keys, I've learnt a lot from them. Indeed, fixed my key issue using the information in them. Chap whose ID is Television is the lead and seems to say only what he has actually observed..
In my case the red lens on the ignition (where the key fob is inserted) was/is dirty. Haven't figured out how to clean it with permanent results, but every time the key plays up I swipe the lens (carefully, gently, no force) with a fingertip (dry or just a little dab on the tongue). That gives me a few goes/ days.
But remember, when my key is playing up, it'll turn in the ignition but car won't crank. And, of course, the remote won't work unless the key is very close to the front door (ie close and pointing directly at the ignition slot (aka EIS). Clean/ wipe the lens and its back to functioning again..
But then, my key is a Frankenstein, thanks to the posts on this forum - I ripped out the coil from a backup key and replaced it on this one because it just wouldn't work and I only had the emergency key to use. Oh how I would've been if I had never come across this forum. (Ignorance is Bliss!)
