Hi folks
Any engineers here?
I,m looking for a 16mm end mill slot drill long series.four flute if poss.I want it to mill a slot out of my gear shift panell to fit a folding mirror switch.
Any decent ironmogers should stock these bits, but I mean decent. You will need a bit for plastic unless it is wood! If there is metal underneath - be careful. The most important thing is bit speed. Too slow is better than too fast. With plastic a slow speed is essential or you will melt the material. I assume you are using a router and has removed the panel! You can try ordering on-line, but you must specify the material being cut. Have you looked at the cost of MB part with hole in? Hope this helps.
Steve K (aka MBenzNL) cut a hole in the (100% plastic) fascia of my car using a drill, powered by a workshop air-line! Some serious skill there! I have pics somewhere.
He was telling us about the time he drilled into his own thumb by mistake, and while telling us he did it again .
we can get HSS morse taper shanks if that what you mean, 16mm is 218mm overall,
also supply blacksmiths parallel shank bits stepped to fit a standard hand held 12.5mm chuck.
Have just got some 6mm file rasps in as well which are handy, drill hole through material and then cut freehand shape similar to a router.
Hi folks
Any engineers here?
