Hi Guys,
Is anyone here running a factory 6 speed W208?
I'm installing the system in a C36 (along with the updated trans tunnel bits to accommodate)
I would like to know how the 6-speed shifter(202/208 267 02 24) bolts to the transmission tunnel cross member?
The original bracket is not quite wide enough and has no pre drilled holes. EPC shows only one bracket was available(same for all 202/208)
On later versions ie W203, this bracket is integrated with the shifter.
Cheers,
Cheers,
