blueserenity777
Has anyone painted their front grill black..thinking of doing it on mine W203..if so, can you share photos..
car is black..so any opinions out there..should i..
I think (?) Tudu painted his first, before he covered it in carbon fibre.
Try searching his earlier threads on his C200.
You need to make sure you scuff-sand it properly first. This gives a key for the paint/primer to stick to.Only problem is stone chips no matter how careful you are you will be forever covering them up weekends.
Tudu,is the car on the left in your picture a w203?If so,where did you get the grill?
Then use either vinyl dye or plastic primer and normal paint for a true colour match.![]()
Clearcoat properly after and say goodbye to stone chips.![]()
Fair enough, I'll defer to your experience of it.That was all done plus 3 coats of clearcoat. You will still get stone chips. Ask a good bodyshop to do it for you and they will probably say the same thing no guarantee against stone chips, that's if they even accept the job.
If like me you do a lot of motorway driving the whole of the front of the car suffers from stone chips, hence the grille placed right at the front will suffer the worst, which is why i went down the CF vinyl route no more chips just minute dents.
my journey to work is motorway driving..50miles round trip..and like tudu, front area does suffer from stone chips..my worry is paiting it all black will look good for a shorttime untill the stonechips get ore visible and then with touchups , it will just get worse and worse..the slats are due for paint again very soon..will ask if they do vinyls..
May come back wrapped in clingfilm ...![]()
Here is my 203 coupe with grey grille & chrome bits painted in Obsidian black
Before & after shots- spot the difference
Smatt - you've transformed the car! Well done. Did you do the spray or bodyshop?
