Hi folks, i am hoping for some advice ( or clarification if i am bing a numpty
Our car is a new 2012 Mercedes B200 D delivered July 2012.
The vehicle is fitted with the new Media Interface. It was unable to recognise our existing iPod Touch ( 4 gb gen 2) , or iPhone 16Gb 4S, and after suggestions by our dealer that it may have been an issue with the wiring in the car, it has now been suggested that the system is only compatible with larger capacity iPod devices.
At their recommendation, we have purchased a new iPod Nano ( generation 6) with 16 GB capacity.
We have checked the compatibility list published by Mercedes, at Mercedes-Benz Bluetooth Connectivity (it lists models for the media interface as well as the bluetooth compatibility) which lists device compatibility for all features, and it confirms it now needs the higher capacity versions for most models. Anyway for the iPod Nano it requires :
A 16Gb iPod Nano 6th Generation, running firmware version 1.2 and using accessory cable A002872104. We can confirm this is the exact specification we have.
On connecting the iPod to the Media interface ( RHS Driver) connector in the centre glovebox, using the one of three supplied cables, the system advises the device is not compatible and to connect to the left hand side regular USB socket. Connecting on this side advises the device is not compatible.
We have tried using a range of iPod devices we have at home ( nano, Touch and iPhone) that worked on our previous (2009) mercedes B class, but all are deemed incompatible (although as most are the smaller capacity models) none match the new requirements published by Mercedes. (Amazingly my wifes new iPhone 4S 16gb is not sufficient specification to connect to her new car, yet on our previous B class, a humble Gen 2 iPod nano worked fine).
There clearly is an issue here, as a customer we should not be left to attempt to resolve this ourselves. The garage seem to be lacking in any ideas, and i can't believe that somehow Mercedes have gone backwards and ceased supporting most of the mainstream iPod and iPhone models. A 16GB iPhone 4S isn't acceptable ? ( I don't want to purchase a 64Gb version just to find out like the iPod nano advice, it too doesn't work).
Having purchased a brand new B Class I believe we are justified in expecting our dealership to be able to advise and assist in ensuring we are able to use the features we purchased with the car, ( a £ 2,100 option for command online with media interface)...so far all they have advised was to buy a new iPod, stupidly we did, and it still doesn't work.
I would appreciate anyones advice on things we could check, or to politely point out what we are doing wrong !!
