ASD warning light
jamsh
London
2000 SLK 320
The ASD warning light on my dash lit up yesterday when I started the car. It's still on. Any ideas? I wasn't aware that I had this fitted!
Its the Anti Slip Diff light, appears to be common, Clean the connectors and replace the relay should cure it :-)
G
I've had a similar problem on my W124 300E
Behind the batterie,there should be a silver relay with 1 or 2 fuses on the relay.The relays are known to cause problems to the ABS-ASD system.
Carlo
