Audio Amplifier - where to fit in E320?
SteveD
Audio Amplifier - where to fit in E320 Estate?
Does anyone have any ideas on where to install a power amp? I've got a CD changer & Nokia kit in the rear but it does not leave much room for an average size amp, typically about 230x200x50mm and needs some ventilation.
suggestions welcome.
SteveD
Steve,
Where are the CD & Nokia kit located?
I've got a changer in one of the side wells in the boot. My amp is flush on the back wall of the boot, in effect on the back of the rear seat.
I can provide a photo if you like.
Any use?
Cheers,
David.
Re Amp positioning
jukie, Thanks for the reply but I fogot to mention mine is an estate - the Nokia & cd are in the rear under floor section ....
Regards,
SteveD
between rear wheel well / hump and rear light - iirc theres a first aid kit here.
on my c class i put it under passenger dash (blocking filter access - but i didnt know that was there at the time...)
under rear seats? (with small computer fan)
have a look at stealh boxes website iirc they have a sub box for the e estate (the c estate sub box on the site was mine) and you could fit an amp in there.. v good quality work.
I made a special made 'thingy' to mount my amp within the space of the spare wheel, there was also room for a 10 disc chager too. Now I have the MP3 player I only have the amp in the spare wheel. Made sure I had enough slack in the cable to enable the spare to easily be removed.
