tonks
Paul,
Touch wood, this hasn't happened to me since. I was driving under similar conditions when it happened (warm engine, S, accelerating etc.) and have since had the ATF changed. Stealer recommended this although I got it done at an Indy. Stealer also said if it happens again, they would recommend removal of the valve assembly for closer examination, but didn't give any indication that they knew the likely or potential cause of the problem. The Indy, however, said he had come across this problem before and the small metal filings in the ATF due to general wear, can be enough to temporarily short circuit a sensor (or something) resulting in the loss of drive (don't quote me on that).
However, you will find a post by Neilupanddown on this board who has suffered the same problem even after an ATF change - his car is also year 2002.
I recommend a trip to the stealers but don't count on them knowing the cause and finding a solution. No harm in changing the ATF anyway. What is your mileage?
Good luck.
Good luck.
