OK time for update and new problem (! arrgh). The car returned last week after a long diagnostic session tracing wires from door to centre console switches to black control unit box (202 820 09 26) in the boot. Taking the door motors apart he managed to clean and lub and they work. Rear passenger door windows not as smooth going up but works ok (suspect motor on last leg?). Rear driver however could only go down not up. His tracing led to replacing the control unit in boot with 2nd hand and it all works now. The B9 pin the culprit. Without schematics for the control unit I didn't ask what B9 was designed to do.
What does not work as before: The closing of windows and sunroof when central locking is engaged. On this car they operate together with central locking. They all closed automatically whenever centrally locked. I was never able to say leave the sunroof tilted if I engaged the MB central locking via main flipout key fob. Symptoms now: At times it proceeds to close the windows and sunroof then stops. Unlock, open driver door, close and central lock again and it sometimes closes them all or again starts and stops. I think its like a timing thing. I think the timing of when and for how long power is supplied needs to be configured. I am almost sure that before, the sunroof would initiate closing only say 1 sec after doors locked. Now it seems to initiate at the same time doors lock and then stops.
Pls anyone gone down this route know - what controls this c/locking+windows+sunroof? Are there resettable settings? Or is it all preconfigured in that control box in the boot - ie the 2nd hand one is no good? Is it one of those things go straight to MB dealership-only?
Help!
