OK this may be re-visiting old ground but I've just phoned my local MB dealer and now I'm confused!
I've a C220CDI with the Audio 20 CD unit. It's an 06 plate (2006). Many forums / postings seem to suggest I can add an AUX cable easily to it.
Pressing CDC on the system does show the aux as active on the display. If I understand correctly this means the wiring for the auxiliary port is there apart from the wire with the 3.5mm jack?
At least that's what I thought but the MB dealer insists that this is only possible on the Command units for this model and that my only option is to get the Ipod kit. (Which I thought didn't work with the latest iTouch / iPhone as their connectors & voltages are different - but MB say different)
Can anybody confirm if this is correct or not? If it's not then does anybody know the correct UK part number I should be asking for?
