BAS ESP warning light
headers21
Scotland
MB C180 Estate
I folks on trying find a fault with my coolant warning light I removed every fuse in the fuse boxes to check none had blown. Restarting the car the ESP BAS warning light has come and stayed on. What gave I done to upset the system and can it be reset.
If your battery voltage went down during your investigation, the ESP and BAS will disable themselves. Start the engine and charge the battery, then switch it off again and back on to see if the fault went away.
Thanks I read that in the manual took for a 5min spin still no joy. Forgot to to say and not sure if relevant changed the pad wear sensors this morning.
Solved turn wheel with ignition on lock to lock a couple of time to reset the sensor angle thanks. Phew
