hi all,my car is ready for a new battery,halfords have a bosch silver 830 amp 100 ah at £130 is this steep?any recommendations appreciated.cheers 95 sl 320.
Previously used Varta Silver (5yr warranty) and also Banner (OEM for Audi) both which I would recommend. Varta can be found widely and Banner not so widely but normally at GSF carparts.
It might be worth checking if you buy a lead acid battery online it may come dry charged, which means you will have to source acid to fill it up (approx.£15-20). Unless of coarse its a sealed battery.
Varta battery gets my vote had my C230K for nearly 10 years and i have covered 130,000miles still with the same Varta battery.
Try your local Vauxhall dealer for batteries.. they sell AC Delco ones, surprisingly cheap, and they came first in the Auto Express battery test a while back..
If you fit the new battery yourself, be sure to use jumper leads to connect another battery to the car first. Otherwise, you will have to re-enter the radio code (not a big deal if you have the code).
Just in case this info is of use to anyone, I bought the same battery as mentioned above (found here) for £92 (delivered) from AutoPoint (www.caraccessoriesandparts.co.uk).
The battery I got is Varta brand, but it is exactly the same battery as the Bosch, but with a different label on it. It is made by the same company (JCI), has the same specifications (100Ah capacity; 830 CCA), 'PowerFrame' silver technology and same 5 year warranty.
To get the (small) discount, just give them a call. Delivery is included in the price. I'd be interested to hear if anyone can get this battery for less.
