Blower motor
petethepilot69
E320Cdi estate, Lexus is200 Sport, Honda VFR750
Hi guys n gals
I have a 52 plate 320CDi estate that developed a heater problem today....
Mrs went to work in her and rang to say the heater motor carried on running after she locked the car?
After 30 mins at her call came back to the car and surprise of suprises the battery was fklat but the blower motor was STILL running?
After a jump start we took the car4 home and took out all the fuses pertaining to the heater and Auxillary heater motors but the fan is still running....
Took the heater control module out adn its STILL running
Have now disconnected the battery ?
CONFUSED.COM
Any ideas??
All replies gratefully recieved in advance....
Pete
:dk:
Hi ive changed my blower motor today to access it there are 2 x T20 screw under the passenger side pull this off then there is a multi plug under neath unplug this and it will stop as this where the power comes from, this plugs into the resistor pack which the fan then plugs into hope that makes sense, just a question did she press the 'ec rest/ac off button' as this puts the heater blower on for about half hour without the keys in the car ? Just a thought but this should turn off once you cycle the ignition. Sounds like a fault resistor pack if you want one ive got the one i took out of my car it works fine just swapped it along with the motor as mine was squeaking when cold for a min or two lol and im a fussy sod :)
Cheers Charlie
Ive removed the undertray to get at the blower gubbins so will have a look at the Resistir and see if thats where the problem lies...
Sounds like that as reading the other posts it seems a common fix....
If I need you parts where about are you ?
Im In Stoke on Trent but we are going to Bradford some time this week?
Many thanks for the reply
Pete
Hi again Charlie
Many thanks for the offer of the resistor.....
Can you pm me hop much you want for it and obviously include the4 postage please....
Took mine out and it deffo defunct....!! lol
Regards
Pete
Hi Pete just need the part number from your resistor pack to check mines the same the part number on mine is A2308216351 or send me your VIN NUMBER il check on EPC sorry for the late reply
Hi again Charlie
No prpbs with the reply
The part I haev taken out is a Valeo part No
539.9875.310
Merc No
210 820 62 10
date stamped 16/01/02 so Im assuming its the original?
Regrads
Pete
:thumb:
Just checked the part numbers and I don't think we have the same resistor packs?
Mine is a curved type with a series of dimples on the top which are heat sink me thinking?
There is a 3 pin block on the bottom and pos& neg spades each side?
Pete
Hi ive attached a pic of the one ive got think your right mine is different :( hey was worth a try tho :fail
