BOOTMGR is missing Help!!
230K
Belfast
09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
Hi
One of the kids laptops is now showing "BOOTMGR is missing Press Ctrl+Alt+Del to restart"
It is a Dell Inspiron N5030 running Windows 7 Home Premium
I have tried Google but without success, I cannot find the product key and dont have a recovery disc.
Can anyone help???
Thanks,
230K
Hi
Update:
I have just found the product key, under the battery:o:o
So do i download a 32 or 64bit version of the recovery disk and go for it??????
230k
The easiest would be to rebuild using the recovery disc - assuming there is nothing you want on it data-wise. If there is, you will want to purchase a 2.5" caddy, take the hard disk out and plug it in to that, and plug that into another computer to copy off what is required.
I wasn't aware you could download Dell recovery discs?
You can use either - if the laptop has more than 3GB RAM, might be better off with 64bit although there isn't a huge difference for most people.
You could just copy in the missing file as a repair job but you need to find an article on how to do it.
Sometimes missing files like that can indicate a hardware issue - usually the hard disk - so it when you re-install from scratch, you can see when you format the disk if it goes through OK.
Update:
Hi
I took out the hard drive and it was empty, I downloaded a Windows 7 installation and loaded it on and it is all up and running perfectly so far.
I have been at this since 11am:mad:
Thanks for the help
230k
Hi
Just realised that my office home and student is for a pre-installed version.
I have the key but no pre installed version
Anyone know where i can download a copy?
230K
Edit
I have just found it
