- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
As you've already found out, having the visor and the Pinloc both scrupulously clean makes a real difference. Ideally, you want to keep the visor closed rather than keep opening and closing it because each time you open it more cold moisture gets in and makes matters worse. If it's raining then opening the visor allows water to run down the inside of the visor from the top which is also a pain. You'll find that as you gain experience and confidence you will become quite adept at holding your breath at critical moments to avoid visor mistingCheers. My visor has Pinloc I think I was breathing too heavy at times and didn't always open it when approaching junctions (too much else to think about). Plus it was full of finger prints, which added to the reflections. As I relax it should improve.
Earplugs is a good suggestion
Regarding earplugs, if you don't want to spend most of your later life saying "pardon" then they're an essential part of motorcycling. The disposable foam ones work well, but custom moulded ones work best and are often more comfortable too. A good local supplier is ACS at Banbury.
