Sandwichmascara
Hi guys
Right I’m having an issue with the brakes locking up seemingly random seems to be the fronts mostly but could be rears too but you feel the fronts first and hot when you touch the wheels and the rears are cold
So I have changed
Master cylinder - NEW
ABS pump unit - 2nd hand
brake lines all round - New
front callipers - Reconditioned
front disks (rotas) - 2nd hand but hardly used
brake pads all round - New
so moving on to the issue I will be driving (most the time) and then i can feel them sticking and i'll pull over and the pedal is solid. i will try turning the car on and off a few times and unplug the abs unit. after say 10-20 mins of either waiting or doing the above maybe faster it’s good to go. but they can either stick or be fine for the rest of the drive/Day.
but it’s not always when driving i was at my garage to drop off some bits and the car was left to idle for say 10-15mins and when I got in to drive off they was solid again?
I’ve been trying different things for a about a month now and nothing helps so I’m here to ask if anyone has ideas etc. to help as I really like the car and don't want to let her go for simple yet annoying hard to find problem.
any advice is helpful and if you crack the problem i'll send you a beer if possible.
Cheers Dan
So I have changed
Cheers Dan
