Not that I know of.
Looks spot on Bill. well done...
Did you do the front only or both ends.?
Well after a bit of olde worlde spannering tonight I think I've succeeded in lowering the front suspension by about the right amount (picture taken at 9:30 - getting dark!):
Took it for a quick drive and all seems OK, will reserve final judgement till tomorrow though
The bar running from the bracket on the anti-roll bar to the electrical box that I assumed was the level sensor was in two pieces - overlapping in the middle and clamped together by a nut & bolt. I was able to get access to this (just) by jacking the OSF of the car. Marked the current position with tipp-ex, slackened the bolt off, shortened the bar by about 4mm, clamped it tight again. Result as above ... a bit jammy!
