C180 W203 Fuel Gauge - Dead? Please Help Mercedes Noob
c180081c
Accrington
C250 AMG Sport Coupe
Hi Guys,
Bought my first Mercedes on Monday, Love the pants off the thing. C180 Elegance 2ltr auto 2002, all the toys however today my fuel gauge has died after a full fill up. So got home and located the sender under the rear seat and had a look at it, The module attached to the float looks very worn. Anyway 3 questions;
The gauge still lights up just doesn't move thus ruling the gauge out?
Can I replace just the sender, would this cure the problem?
If this was a rear SAM issue would everything else also not work?
I didn't risk trying to get any voltages from anything as I assue it is CANBUS controlled and therefore more delicate than fine china.
All help is much appreciated as I am a Mercedes noob and utterly lost and mad.
You will have 2 senders, 1 in each side of the tank.
You need to get it on a star diagnostic where the rear Sam can be read to check levels & also the gauges can be checked with in cluster.
Thanks mate, I just hope it doesn't get too expensive
The fuel gauge started working halfway to work after I removed the left hand side fuel sender and cleaned it last night, however when i turned the ignition off and back on it was dead again. Would this indicate I need to replace the lefthand side sender? I assume this means the SAM unit is working fully in the rear. I am having trouble finding someone who can get the care on star for me without a waiting list.
