Or it could be the reluctor ring or magnetic bearing if it has one.
The wife's B200 ABS sensor showed a failure 2 years ago, turned out to be the magnetic bearing, I did buy a new Febi sensor for about £30 and that's still working fine.
Easiest thing to do is swap the sensors over and see if the problem goes to the right side, just to prove its the sensor.
