biltong11
Hi
I am having a problem with the heater booster on my C220 CDI W202 (W Reg - 2000). The heater booster seems to run all the time. I can park the car up and go out three hours later and it will be running. I can feel the hot air from the little exhaust under the front right bumper and smell diesel. I have the system Off on the centre console (light in the switch is illuminated) but it makes no difference.
This problem seemed to appear only after I had all four tyres changed and alignment done last week. Before then it was fine. (Since the tyre change I also have the BAS ESP dashboard on permanently.) I am taking the car back to the garage as the alignment seems to be a little off, and I believe this could cause the BAS ESP lamp to come on.
So, help! Any ideas on the heater booster? How do I turn it off. I don't believe I need it - the outside temperature is currently in the mid teens so I'm sure it's not required.
As an extra point, I have also noticed the engine temperature never seems to get above 50 degrees. It has been like this since I got the car a few months ago, but not sure if this has any bearing on the problem.
Thanks for any assistance...
