c240 gearbox problem/possible sale
Nick
Is that the price £140 That sounds good is it definitely the one for the Tiptronic box?
How easy would it be to fit
Or is anybody in the Essex/London area that could help with fitting for a price?
What part of the london/essex area are you in as i might be able to help
Hi Willow
I'm In Romford Essex
Can travel a bit but obviously its only in first gear
As i think the car has gone into limp home mode
Well just stuck romford in aa route planner and its about 50 miles from me which isnt too bad
Hi Willow
Yes thats not too bad
If i get the one off of Nick would you be able to fit? obviously for a fee
How does the coding thing work so that the module matches up to the car?
Unfortunately i can't PM you as i 'm a newbie
Yeah that sounds good we can sort a price out.
The coding is not an issue as i have a star machine to do it
Dead battery and auto gearbox failure..?
I have the same problem... I took the battery off for three weeks... Yesterday I replaced it... Started the engine... The car was on a limp mode on "D"... Not changing gears... Moved to triptonic mode... Changed the gears manually... The gears were changing as usual... 1-2-3-4-5... Stoped the engine... Started with the same problem... Not changing gears on "D"... After several trials it started to work as usual... First with no power at the beginning... For exemple on a traffic light... Later started to react normally... After half an hour of drive everything became normal... Today the problem came back...
My SLK is a European 1999 with a 2000 cc non-compressed engine (111.946) and an automatic gearbox (722.602)... The codes that the service provided me are 97, 132 and 135. I don't know if these codes are different from the UK codes... Based on the above mentioned error codes can anyone help me to diagnose the problem..?
What was the solution in your case..? What might have been the problem..? Something related to the memory of the automatic gear box..? Maybe the memory was erased because of the absence of the main battery..?
Any ideas..?
Solutions to all my problems...
Here are the solutions...
I changed the front “donut” of the propshaft... The one which just after the gearbox... No more jerking...
I changed the battery (60AH/540) with a more powerful one (74AH/680)...
Changed the oil and the filter of the gearbox... Believe me it has to be changed what ever the dealer or the servive manual is saying... Added also an internal magnet...
Result: Like a dream...
Exactly the same problem that I had with my 2004 C200 6 months back, mine was a gear selector module replacement cost me £600 all in at the time. mine had to be recoded to the ECU by mercedes.
Since found out that Merc repairs of croydon can do the fitting and the recoding for a much cheaper fee.
My car runs fine now.
