C240 wheel specs
Rydin LoW
hey guys... my friend is interested in getting 18x8s for his C240... can anyone tell me the specs?
offset range
lug pattern
tire sizes recommended
all help is much appreciated!!!
I run 8x18's on my C Sport (see pics) My tyres are as follows....
Front 225/40/18
Rear 245/40/18 255/35/18 will fit though 265/40/18 will also fit but may need arches rolled.
Offset, I can't remember... but mine were off a CLK Cab.
Did you have any problems with the rears, when I put the 18's on the rear the wheel bolts where too long and fouling the rear brakes, I ended up buying new bolts for the rear, ahs anyone had this problem before.
Thanks Jon
weird, i took my 17`s off and the 18`s went straight on!, had to bend back the rear arch slightly as i couldnt afford to change the 265 tyres on the back!
n3thn, wrong offset is the only thing i could think of!
