KNU7S
- Apr 10, 2006
- Location
- Gloucester
- 1991 R129 500SL Mercedes, 2002 ML270cdi, 2004 Freelander
Im fairly sure what the problem is but could do with confirmation from you guys.
My C250 had a problem with water coming in through the heater which was soon cured when i cleared the drainage hole in the heater box under the bonnet.
That was 3 months ago, now the heater blower has backed up, im asuming the water has knackered the motor even thoughthe fuse has not blown.
If i replace the blower motor will this cure it or is it the speed resistor?
