Hi
My 1998 C250TD w202 has developed the weirdest fault. When I start the car, the rear offside passanger window opens about an inch! Its only been happening for about 2 weeks, I cant think of anything I`ve done that would cause it. I have found a blown fuse in the boot (number 7, 5A) which blows again as soon as I change it, I dont know if this is related or not, everything still seems to work even though its blown. After the car has started, the windows work normally, so it only seems to happen while the starter motor is engaged.
I have been told it could be an earth fault, but I`ve checked all the brown earth wires under the bonnet, and they all look clean, though I did also clean them all and smear them in vaseline just in case.
Has anyone come across this before?
Gary
Gary
