Mornign all,
My 97 c250 td will only select 1st when put into D (acompanied by a jerk), you can get reverse and neutral but in D it just goes to the red line and wont change up even if you try manually moving it.
I have a new filter, oil and gasket coming this afternoon so I will be installing this.
There is plenty oil in the box, and it has 101K miles.
I have done quite a bit of searching on this site and noticed alot of people mentioning gettting the codes read on a star machine, Is this a generic analysys machine or a merc specific??
I really dont fancy driving the car anywere due to having to rev the plums off the old girl.
If its worst case senario, are all W202 boxes the same or will i need a TD spec version.
Many thanks in advance
