Generally speaking, you can get around 3% better mpg from a manual petrol than an auto, and 5% better mpg from a manual diesel than an auto.
With a manual diesel of course you do not need a fixed fuel air ratio, so you can have a wide range of fuel usage per cylinder stroke, from bare tickover to cuffing it with excess fuel.
The real secret is not wasting energy, eg mass of vehicle x velocity of vehicle.
Find a nice quiet bit of flat surface, maybe an empty car park, pick an object / marker, put a marker out, then walk in a line an put another marker where you think the car will coast to and put your second marker.
Then do it in the car, get up to 10 mph (5mph if you can see it on your speedo) and as soon as you pass the marker going straight take your feet away from the pedals and shift into neutral (manual or auto, you can shift to neutral in an auto an tickover rpm and 10 mph or less, never shift into gear though) and see how far you go.
Racing drivers often pick a similar place but with a small slope, then just coast from a mark, repeat 20 or 30 times working your way through a range of tyre pressures (and of course tyre types) again, an astonishing range of variation.
NB
I am NOT talking about hypermiling or other dangerous driving techniques.
I AM talking about advanced driving techniques, plot a course down the road, obey ALL the regulations, and run the course with the minimum number of control inputs, and with each input itself the minimum amount (eg smallest steering wheel deflection, smallest braking, smallest acceleration).
You HAVE to read the road ahead to do this.
Positive benefits.
NB
Positive benefits.
- You will become a much safer driver, and other road users will find it much easier to "read" your intentions.
- You will reduce your fuel consumption dramatically, 25-50%
- You will reduce brake / clutch / tyre wear dramatically, 300% or more
- You will reduce mechanical wear and tear dramatically, 1000% or more
- Your journey times will AT WORST be the same, probably be shorter (lights in a 30 zone are usually timed to 25mph)
- You will never get a fine or endorsement.
- You DRAMATICALLY (orders of magnitude) reduce your chances of being involved in an RTA.
