C350e engine start problem
AshB123
Wales
C350e
Hi guys,
Thanks in advance for looking at this thread, and I apologise if this has been spoken about before
My Hybrid C350e has recently developed a problem, when in 'Hybrid' mode and its running on the batteries, when I put my foot down, and the 'E-Drive' indicator hit the red mark, the car seems to be hesitant on starting the engine to provide the power that I'm looking for.
Also I have noticed that when stationary and I select Sport from Comfort, the engine used to start straight away, now I can hear a whining noise like its trying to start, but nothing happens.
Thanks again for taking your time to read the thread, and I hope that its not a bad diagnosis
Hi Ash,
Did you find out about the issue?
Hi guys,
Hi Ash,
Did you find out the issue? My C350e, just developed and started the same issue you had. I changed the starter about a year ago.
Thanks.
I have same kind of problem in my C350e did you find some solution about this?
Hi guys,
Usually it's the starter motor starting to fail, check for fault codes
