C36 - Low Spec?
I've checked the number plate and it does say its a "C-class 3.6" which would make it a C36.
Unusual that it has no leather, but then the original owner, might not have liked leather and preferred fabric instead - like myself.
Thats a very early model C36 AMG and if im correct the very early ones did not have leather as standard. Does look pretty standard apart from the AC and Cruise.
Me too, really not a fan of leather, but would never tell a seller that! Good mileage for a '95 and a nice looking car.
Apart from the fact that it wouldnt get 30mpg if it was being towed :eek:
I'm going to bid on it anyhow and if I win.. swap over the leather from my C280.. and flog my C280 sport without leather..
Badge on the back is in the wrong position , make sure you check for poorly repaired accident damage .... if they can't be bothered to put the badge back in the right place , what is the rest of the work like ...
Also , sellers that 'big up' cars ( eg , this chap says it has 300bhp but it doesn't ... ) worry me , as it can suggest that it has been ragged. The mileage is suspciously low as well , i would ask to see documentary evidence that it is correct ( unless it is DIRT cheap ) , when things go wrong on these , they are expensive ...
Heres the spec ...
M666 JAB
VIN WDB2020282F28****
Model C36
Chassis 2020282F28****
Engine 104941 22 058585
Transmission 722328 04 179321
Order 0 5 537 75763
Delivery date 01.08.95
Dealer Great Britain (537)
Interior cloth "Magnum" black (601)
Paint
744 brilliant silver metallic (с 1991)
Options
212 electronic traction support (ETS) (с 01.06.1993)
240 outside temperature indicator (с 01.03.1982)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
341 additional lamp (с 01.09.1982)
420 automatic transmission, floor shift (с 01.01.1963)
441 steering column, electrically adjustable, W202 manually adjustable (с 01.07.1984)
440 tempomat (cruise control) (с 01.09.1975)
461 instrument with mileage reading and english lettering (с 01.04.1990)
516 radio MB Classic without traffic news decoder (VK) (с 01.07.1992)
531 automatic antenna (с 01.01.1963)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
584 electric window lifters (front and rear doors) (с 01.04.1970)
electric window lifters, fourfold or sixfold
580 air conditioner/Tempmatic (с 01.11.1982)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
613 lamp unit, asymmetrical, l.h. traffic (с 01.02.1963)
655 sports suspension with light alloy wheels, 5-hole (с 01.07.1992)
673 high-capacity battery (с 01.01.1964)
776 wheel cover for amg 17" wheels (w202 export only) (с 02.11.1992)
772 amg styling package - front spoiler, side skirts and rear apron (с 02.01.1992)
774 Shell modification for AMG-wheels
833
957 AMG technology package (с 01.01.1992)
extension tube on the roof, front left
956 equipment package sport (с 01.11.1991)
984 elimination of ownership certificate but with coc papers (с 01.06.1993)
A low spec model like that would make for an excellent track-day car surely? Take all the seats out and put a racing shell in, roll-cage, dump most of the interior, have the aircon disabled etc. Would be great! :D
That WOULD be great!
Leem, he's in Cornwall too - are you gonna go see it?
shude, was gonna say the same thing, I think the rear ended E55 would be fast but a bit of a heavy hector for a track hack, this makes more sense, especially if the interior isnt great, your gonna bin it anyway, the only thing is cloth seats are a bin job, at least leather has aftermarket vale,
agree with the interior strip and air con disable, would also recomend a shorter belt so the pump isnt driven and take as much of it out as possible, you would be amazed what you can take out for a track hack, we did an Alfa at college for the Alfa only series, took a power hacksaw to the dash, most of the clocks - really went to town, it was quite fun!
however for real drivers how much use is a track hack with an auto box?
Fit gearbox and clutch from a C280.
and cut hole for pedal and another pedal box and the gearbox ECU will be linked to the engine ECU, or is it that easy? in which case I may be buying a rear ended E55 for a manual conversion!!!
The only reason I saw this is a friend converted an auto Punto to a manual and he said never again, it was soooooooo much grief,
What gearbox ECU? There's little electronic trickery in the pre-facelift c280 and c36, they're dinosaurs electronics-wise :)
If you put a c280 manual gearbox on an e55 it will be broken within minutes I'm sure. You need something a lot beefier.
would the C280 box take the C36 power anyway? i assume its the same box as i had on the E230 and it was rubbish!!!
merc engines and boxes - do they all have the same bolt pattern?
