Hughinafrica
- Aug 16, 2007
Hi there,
yesterday my gearbox started playing up with the following problems:
1. When I pulled away from a roundabout the box jammed in second gear. When I accelerated it would not change up and I could not over-ride it with the tiptronic. I had to pull over, switch the engine off and restart and it seemed fine.
2. Then later on on the same journey i was overtaking. When the box went to kick down out of 5th, it went into neutral and jammed and again I could not over-ride or select any gear with the tiptronic, so had to freewheel to a standstill at the side of the road, switch off the engine and start again. This happened again later on the same journey.
I had the gearbox oil changed less than a year ago and have never had any other probs with the gearbox.
Any thoughts as to what the cause of this could be? Thanks in advance.
