Feeble
I have got an issue with my car at the moment, it is not starting on the key first time as it usually does. This started happening after I drove through a flooded road and got the car soaking wet (stupid...).
It normally fires up on the second attempt. The first try is always a failure when the car is cold, but there is a scraping noise from the engine and the rev counter goes up a bit too.
From what I've seen on the forums, it could be a starter motor issue, and it might need some lubricant on the shaft... Do you think this sounds ok?
I need to know where exactly the starter motor is located? I can't see it from the top so assume I'll have to get it up on the ramps. Don't know if I am being thick, but I can't work out the location from any photos of C43 engines that I have found on the internet either... Also, what is the best lubricant to use?
Any and all advice will be appreciated!
