Cable duct into boot
Xtonys
Birmingham
2015 c class coupe amg prem plus
Hi Everyone
I have a very nice 2015 c class coupe amg... 1st time mb owner...
I want to fit a Pioneer active sub in the boot.
It needs 10amp switched power (only need it when engine on)
audio feed from any main speaker (not tweeter)
Sub controller lead run through to the centre armrest storage bin
I have been searching around for advice on a couple of questions...
Hopefully you guys can help...
It looks like cabling into the boot runs down the drivers side to boot fusebox, with wires under the rear seat base?
Is it possible to feed a couple of cables into the boot without removing the rear seat?
If not is there a guide to removing the seat?
I guess wiring off a rear side speaker is easiest?
I dont think the speaker mesh will pull off, so do i really have to strip out side panel to access the speaker cables?
What colour are the speaker cables btw? Maybe i spot them in loom under rear seat?
Anything i need to know about dropping down boot carpet on one side? Looks like pinch clips ?
I have comand online audio system ntg4.5 i think...
Is this the one with a fibre linked speaker breakout box?
Also its an mb Agility car and 2 years warranty left... should i notify anyone of adding a simple speaker wire? The power will come off a cigar socket as in my previous car.
Appreciate any ideas...
Tony
