Calling all 220 CDi owners - Help!
Wully
Glasgow
2002 W203 C220 CDI Avantgarde SE Auto
Guys
Would it be possible for any of you to check the black plastic item shown below which houses the small indicator to see if there is any movement in it.
For some reason my cover well the whole unit seems loose towards the rear of the engine bay.
Do any of you know what holds this in place if it is infact loose. Would this effect performance?
Cheers
The bit you've arrowed is the lid of the airbox containing the air filter.
It has 2 bolts with rubber mountings holding it to the side of the engine, and it is supported at the top by 2 rubber retaining washers that clip over mountings. a bit of movement is normal.
rob
Cheers Rob
I'll have a good look tomorrow.
