Centre caps.
Mobb
London
CLK55 AMG - E92 M3
The Kleemann centre caps I have are fairly rare and are hard to get hold of.. Also prevention is better than cure.
How can I make sure that they are secure and dont fall off? As two of them seem a little loose.
Mobb.
Clean the inner part of the hub well and use a small dab of silicone sealant.
Not familiar with silicon sealant.. Is it easily removable? Won't do any damage? Where can I get it from?
Would double sided tape be a safe option or is silicon sealant the best way to go?
Any good plumbing shop will sell silicone sealant. It is removeable and won't do any harm.
You could use double sided tape if you can find a suitable surface to stick it to. Make sure you clean the back of the cap and the wheel with Methylated spirit before you use tape.
Have a local DIY shop around the corner..
Thanks for the info. :)
