Morning Everyone
My 2002 CL 500 - W215 Airmatic problem. The white airmatic warning came on, the warning then changed to red withing a couple of minutes. As I was gently creeping home, the slightest bump on the road started the rear end 'Bouncing', caused by overcompensation from the hydraulics and sensors, which wasn't a pleasant experience, even at 25-30 mph.
As a previous Citroen owner with the similar type of suspension, I experienced much the same with that. The Spheres were the cause on that occasion.
Before I go and source these, can anyone confirm if they have had the same problem and if changing the spheres solved the issue, as the W215 system is a touch more complex than the Citroen system.
