TucksMirror
Hi all,
Quick query that I was hoping for some help with.
I have been redoing some items on the front suspension relating to an MOT fail and advisory items. I am in the process of installing new control arms and brake discs. (The discs are rusted to the hubs, nightmare).
The whole front area has been a bit of a challenge, and there is now a small pile of rust growing under the front hub on the floor
In the process of disassembling everything the brake disc dust shield disintegrated due to being extremely rusty, so I pulled the rest of it away intending to replace as well, and I now have the part.
I have come to the realisation that I need the wheel hubs off to replace the dust shield.
The Haynes manual states that you should not refit a hub and bearing assembly with the same bearings. Can anyone confirm if this is true in practice, or if I can get away with using the same parts? I am not looking forward to refitting the hubs as getting the right play in the bearing, within those small tolerances seems tedious.
I was hoping to avoid more spending, but will do so if necessary.
One more query! I am going to replace the rear springs, and am intending to lower the rear control arm down with a jack rather than use a spring compressor. Is there anyone with experience of this who knows how far the down the arm needs to swing to let the spring come free? I ask as I plan to do this job on the drive, with the car on axle stands and not too high in the air.
Thanks in advance.
Thanks in advance.
