Hi Oleks just an update, everything sorted car back on the road.Okay buddy thanks will replace clutch also.
Thanks again for everything and will update you when finished
Replaced flywheel with a Luk make rather than Mercedes as the Mercedes are prone to losing the splines.
As for the clutch, Mercedes couldn’t get me one. They said non available in uk or Germany! Another fella even said they discontinued. And so we ended up buying a used gearbox with clutch with only 59k on the clock with same part number AND same gearbox code…and just putting our original TCU into it.
Managed to get gearbox out without removing subframe but getting it back in was fun ( NOT) ha.
So to anyone reading this with these codes with a 724 gearbox and thinking it’s down to the TCU
092500
07e600
071564
Then chances are it’s going to be your flywheel at least and possibly your clutch also.
Oleks….. thanks for everything and all the best for the future.
