What, my experience is wrong! Unfortunately that's the problem with past experiences, it cant be changed.Yes it wll
I used to bar but have found clay-mitt and also clay-cloth so much easier to use, quicker and also less forgiving to damage/marring.
Would never dream of claying if not undertaking a full-on build (eg strip,clay, polish, glaze/seal, wax) thus ALWAYS polish after clay.
1/2 a day won’t be anywhere near enough time to prep/polish/wax a 212 estate.
My advice if you’re short of time would be to do it in stages - that’s what I have done in the past. Wash the whole car as usual then use iron fallout remover and then go around and decontaminate one or two panels thoroughly (tar remover and clay) then polish and apply wax or whatever you choose to those individual panels. If you do a couple of panels at a time in the summer evenings you can get the whole car up to a really good standard over a week or so.
Makes it a less daunting process and much more realistic if you don’t have whole days at once to dedicate to car polishing etc. Even a whole day won’t be enough time to polish the paint properly, the paint used by MB on this era is incredibly hard (might be the ceramiclear/nano lacquer - not sure?)
Once up to a good standard you should find it much easier to maintain. But it does take a long time to begin with!
As an interim you could wash, fall out remover, wash, clay mitt, poorboys black hole (if it’s a dark colour, or autoglym super resin polish if lighter) then a good wax. If short on time a liquid wax like Meguiars ultimate liquid wax is good and easy to use. You could just about do that in half a day by hand If the weather is on your side, and you should see a good improvement. If you have a bit more time you could use meguiars paint cleaner after the clay mitt. But as said above to do it properly you’re probably looking at a couple of days or more, especially if there’s a lot of paint correction to do (swirls etc). But I’ve found the black hole is a great cheat step if you’ve got a dark car. My E250 Estate is Tanzanite blue and it works a treat if you want a quick improvement.
I'd never clay a car unless I'm going to be machine polishing it afterwards.
You will inflict clay marring - where the clay surface picks up hard contaminants and you rub it across the paint.
Now if your car was a few years old and had lots of swirls etc then you may not notice the clay marring being inflicted.
Your car is a year old and in theory the paint is still in good condition so you are much better off using the tar remover on tar spots with several microfibre cloths. You will also benefit using a chemical decon in the form of Carpro IronX, or Bilt Hamber Korrosol.
Have you come across this YT video? -
Cheers,
Chris
I've been using Super Resin but will have a look for some Black Hole thanks.
The blackhole works well at hiding swirls (as does the fillers in Super Resin but for dark paint I prefer blackhole) but you do need to put wax on top or it won't last. Smells of grape as well!
FWIW, Poorboys class bright solid red as a dark colour (I have both Black Hole and their White Diamond - for lighter colours - and I didn’t know which to use when I bought my red car, so I asked them!).I've been using Super Resin but will have a look for some Black Hole thanks.
Thanks for the tip. My poor 212 is badly in need of a proper deep clean. I've bought a clay mitt and a big bottle of Dodo Juice (Born Slippy). I've got plenty of wax & polish in the shed and a d/a polisher which I've never used.
In the next few weeks when I can find a spare half day the plan is to hand wash it, dry it, clay mitt it, wax it, polish it and then maybe add some sort of sealant/top coat* ** ***
What do you apply (if anything) after the wax?
*and then, at some future date, polish & wax the wheels.
** and then, after that, revert to hand washing it myself the majority of the time.
*** must buy some wellies
I think that if you polish after waxing you will clean the wax off.
Maybe polish/seal/wax would work better.
Polish is abrasive and used to smooth the bare paint, so it'll need sealing afterwards with either wax or sealant.
Ah OK thanks.
So maybe
- clay mitt
- then a polishing session with whatever polish & the DA polisher
- follwed by the wax?
