CLK Speakers Missing
bhav
Solihull
CLK200K Avantgarde
Hi peeps, was thinking of putting a sub in teh boot of my clk when noticed speaker feed from the speakers on the shelf as i dont have any, lifted up the grills from the inside but all it has is these foam inserts.... any ideas? or do you think previous owner removed them??? I have heard that some only have one anyway but surely its strange not to have any.
I have never sat at the back to never realised all the sound stage was at the front of the car.. :(
sad to hear that but never the less as long as the wires are there and you know the measurements you can buy some and fit them with out any problem, some pioneers or alpine would be good in my opinion
just went to have a look no wires... :crazy: was the back speakers an option???
if the wires are NOT there then unfortunatly they must be have been an option if you pop down to your local dealer and grab the CLK brochure and options list you can check for shure if they are an option. If i have the brochure ill check for you. Sounds real stupid though if you ask me Mercedes of all cars having rear speakers as an option even on an Avantgarde the range topper
Given similarities between the 203 and 209, I suspect the hi-fi options are the same too.
In the 203, only cars with the optional BOSE hi-fi have speakers in the rear deck - and then only on one side as it's a sub.
I would imagine it would be possible to retrofit speakers there though.
thanks mate..
I still have these from the rear deck of my w210 rekon i could use these to get a lil more bass??
This has got me wondering if there is any in my rear shelf :confused: ,I will go have a peek later.
What size are these speakers, should be written on the back of them if not you can simply measure them with a ruler, they look like 13cm's to me though. If you wish to put these in your CLK to get that extra bass you must inshure that the space in the CLK is also (for e.g. 13cm) best to measure the space also, if they are then you in luck if not then you may have to buy some new ones i can guide you on some good bassy ones if that be the case. In all you will still need to retrofit a wire from the head unit to the left and right rear speaker !!!
Yep I have downward facing ones,Don't know why they are that way(possibly to keep the trunk monkey happy :D )
Just looked in the price guide.. defo no option for rear speaker meanin it should be stock :(... but no wiring so very confused ... the speakers from my w210 are 17.5 cm
Pluggers there like that on my W202 also i believe there done like that to produce a BETTER effect on bass
That must mean the previous owner must have taken the rear speakers and cut the wires meaning the must have fallen a bit back, you may have to look harder because they MUST be there somewhere, try both sides see if there there on the other side and measure the rear speaker space that way i can advise you on some good speakers to buy.
Sounds like they have been changed on the facelift models.If I remember right on my old W202 they faced upwards.
I swear bhav's CLK is the new shape W209 and pluggers is the previous shape W208 !!!!!
Me too.
I suspect in the 209 the rear deck speaker grilles are empty unless there's an upgraded audio system - like the 203:
bhav - do you speaker grilles in the side rear panels too? If so then these will be the standard rear speakers.
Me too.
Hi, no there are no speker grills in the rear side manels just at the fron and rear of the roor mate.
