clk320 w208 climate control
Clkmaker
clk 320 w208
Hi to everyone,
If this is in the wrong area I am sorry and ask please would you place it in the right area.
Today I found that I could not turn off my ec light and after reading the owners manual I had the air con system regassed. After the car was regassed I found that I still could not turn off the ec light no mateer what I did. I needed to go shopping and left both settings to low and took a drive to the shops. Whilst driving there I noticed very cold air coming out of all air vents. The ec light was still on and could not be turned off. Getting to the shops I turned the engine of and then on impluse started the engine again and this time I could turn the ec light off.
I did my shopping and returned to the car feeling happy. Upon starting the car I found the ec light on again and once more I could not turn it off. I drove home and once there I had a thought and once parked and turned the engine off I then turned the ingnition back on but did not start the engine. The ec light came on and I pushed the button and the light went off. I turned the ignition back off and then once more turned the ignition on with out starting the engine and the ec light stayed off.
Please would you help me to get my climate control working as it should Ie the problem with the eclight and economy mode etc.
Many thanks
mine is the same think it may need to be put on the star.
If the system has got low on gas it will log a fault code, even though it now has been refilled the fault code is still there and needs to be cleared with a diagnostic.
With a digital display you can access the fault codes and clear the fault "hopefully".
Hope you find his helpful.
Digital Climate Control fault codes and diagnostics.
SELF-DIAGNOSTICS
DIAGNOSTIC TROUBLE CODE READOUT
Entering Diagnostic Trouble Code (DTC) Display Mode
1) Turn ignition on. Press down arrow push button until "LO" is shown in A/C-heater control panel temperature display window.
2) Within 20 seconds, simultaneously press REST and defrost push buttons for more than 2 seconds. The Light Emitting Diode (LED) in the recirculated air push button will blink and the display window will show "di R".3) Press AUTO push button repeatedly, recording each DTC,until all DTCs are displayed. Permanent malfunctions are displayed first. See DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION tables.
4) If no permanent malfunctions are stored, the display window shows "En d". Press AUTO push button again. Intermittent DTCs will be displayed. Intermittent malfunctions are recognizable by the degree (°) symbol displayed along with the DTC (example: "04 °").
5) If no intermittent malfunctions are stored, the display window shows "En° d". Proceed to ERASING DIAGNOSTIC TROUBLE CODES.
Erasing Diagnostic Trouble Codes
1) After display window shows "En° d", press AUTO push button once again. Display window should show "dE L" (delete).
2) To erase DTCs, simultaneously press down and up arrow push buttons for more than 5 seconds. The display window should show "- --". If not erasing DTCs, press the AUTO push button. The permanent DTCs will again be displayed. Proceed to EXITING DTC DISPLAY MODE.
Exiting DTC Display Mode
Simultaneously press down and up arrow push buttons until the pre-selected temperature setting of "72 °F" is displayed. Turn ignition off.
DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION TABLE
Code(s) (1) Cause
01 ......................Normal
02 ......................A/C-Heater Control Panel
03 & 04 ..............In-Car Temp. Sensor/Blower Short Circuit
05 & 06 ..............In-Car Temp. Sensor/Blower Short/Open Circuit
07 & 08 ..............Outside Temp. Sensor Short Circuit
09 & 10 ..............Outside Temp. Sensor Short/Open Circuit
11 & 12 ..............Heater Core Temp. Sensor Short Circuit
13 & 14 ..............Heater Core Temp. Sensor Short/Open Circuit
19 & 20 ..............Evaporator Temp. Sensor Short Circuit
21 & 22 ..............Evaporator Temp. Sensor Short/Open Circuit
23 & 24 ..............Engine Coolant Temp. Sensor Short Circuit
25 & 26 ............. Engine Coolant Temp. Sensor Short/Open Circuit
27 & 28 ..............Refrigerant Pressure Sensor Short Circuit
29 & 30 ............. Refrigerant Pressure Sensor Short/Open Circuit
31 ......................A/C Compressor RPM Sensor Circuit
32 ......................Drive Belt Slip Recognition Circuit
47 & 48 ...............Auxiliary Coolant Pump Short Circuit
49 & 50 ...............Auxiliary Coolant Pump Short/Open Circuit
51 & 52 ...............Duovalve Short/Open Circuit
53 & 54 ...............Duovalve Short/Open Circuit
59 & 60 ...............A/C Compressor Clutch Circuit
61 & 62 ...............A/C Compressor Clutch Short/Open Circuit
63 & 64 ...............(2) Auxiliary Fan Activation Short Circuit
65 & 66 ...............(2) Auxiliary Fan Activation Short/Open Circuit
67 & 68 ...............(3) Auxiliary Fan Activation Short Circuit
69 & 70 ...............(3) Auxiliary Fan Activation Short/Open Circuit
(1) - Other than codes 01 and 02, the even numbered codes indicate an intermittent malfunction.
(2) - Auxiliary (condenser) fan stage 1 (low speed).
(3) - Auxiliary (condenser) fan stage 2 (high speed).
Code(s) (1) Cause
71 & 72 ....Closed Throttle Speed Increase Short/Open Circuit
73 & 74 ....Closed Throttle Speed Increase Short Circuit
75 & 76 ....Diverter Flap Switchover Valve
77 & 78 ....Diverter Flap Switchover Valve Short/Open Circuit
79 & 80 ....Tempering Flap Switchover Valve
81 & 82 ....Tempering Flap Switchover Valve Short/Open Circuit
83 & 84 ....(2) Fresh/Recirculated Air Flap Switchover Valve
85 & 86 ....(2) Fresh/Recirculated Air Flap Switchover Valve Short/Open Circuit
87 & 88 ....(3) Fresh/Recirculated Air Flap Switchover Valve
89 & 90 ....(3) Fresh/Recirculated Air Flap Switchover Valve Short/Open Circuit
91 & 92 ....(2) Defroster Flap Switchover Valve
93 & 94 ....(2) Defroster Flap Switchover Valve Short/Open Circuit
95 & 96 ....(3) Defroster Flap Switchover Valve
97 & 98 ....(3) Defroster Flap Switchover Valve Short/Open Circuit
99 & 100 ...(2) Footwell Flap Switchover Valve
101 & 102 ..(2) Footwell Flap Switchover Valve Short/Open Circuit
103 & 104 ..(3) Footwell Flap Switchover Valve
105 & 106 ..(3) Footwell Flap Switchover Valve Short/Open Circuit
(1) - Even numbered codes indicate an intermittent malfunction.
(2) - Long (80 percent movement) stroke.
(3) - Short (20 percent movement) stroke.
READING SENSOR VALUES
1) Turn ignition on. Simultaneously press down and up arrow push buttons until the pre-selected temperature setting of "72 °F" is displayed. Press the AUTO push button.
2) Press REST push button for more than 6 seconds. The display window will alternately show "01" and an in-car temperature of "72 °F", or "LO" if there is an open circuit, or "HI" if there is a short circuit.
3) By pressing the windshield air distribution push button, the next ascending test step is displayed. By pressing the footwell air distribution push button, the next descending test step is displayed. See SENSOR VALUE DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION table. Press REST push button to exit reading sensor values mode.
Code Cause/Value
01 ............................. In-Car Temperature Sensor
02 ............................ Outside Temperature Sensor
03 ........................ Heater Core Temperature Sensor
05 .................... Evaporator Core Temperature Sensor
06 ................. (1) Engine Coolant Temperature Sensor
07 .............................. (2) Refrigerant Pressure
08 ............................ (3) Blower Control Voltage
09 .......... Software Status Of A/C-Heater Control Module
15 ........................... Selected In-Car Temperature
20 ................................. Software Version Code
21 ...................................... (4) Engine Speed
22 .............................. (5) A/C Compressor Speed
23 ......................................... Vehicle Speed
50 ................................ 80.° - 00.° (Not Used)
51 ......... Number Of Actual Drive Belt Slip Recognitions
52 ......... Number Of Actual Drive Belt Slip Recognitions
(1) - A display of "12.°5" corresponds to 125 Celsius (257°F).
(2) - Refrigerant pressure is displayed in bar. One bar equals 14.5037 psi. A display of "12.°8" corresponds to 12.8 bar (185.6 psi).
(3) - A display of "16.°5" corresponds to 1.65 volts.
(4) - A display of "06.°0" to "70.°0" corresponds to 600 RPM to 7000 RPM respectively.
(5) - A display of "00.°0" to "84.°0" corresponds to 0 RPM to 8400 RPM respectively.
