Coding after retrofit audio20 to ntg2.5
yiannossavva
w211 Estate E200
I already retrofit audio20 to ntg2.5
The unit works fine.
I want to activate the backup camera.
The problem is that my diagnostic tool Mb star don't recognize the ntg2.5
How can I code it?
From the engineering menus?
Have you looked at the thread by gmatj if this detail would be covered?
http://www.mbclub.co.uk/forums/electronics/96633-all-you-wanted-know-about-comand-aps-ntg-2-5-a.html
Unfortunately the post not help.
I want to (say) to my car that now you don't have audio 20 but ntg2.5
When i scan the diagnosis scanner can't see the ntg2.5, so i cant say to my ntg2.5 that i have a buck up camera. In engineering mote thes is no option to activate the buck up camera
I can def recommend the guys at comand online, tried a local Merc specialist for mine and they really messed it up! The guys at comand online sorted it all out :-)
You need developer mode for the audio gateway. But this has been deleted in more recent version of STAR. So get an earlier version or get a hacked version of the later STAR.
I have the hacked version
How I can activate the buck up camera?
The reverse camera can only be activated in developer mode of STAR.
You need a hacked version of developer mode that has the audio gateway menu. From the gateway menu just enable the reversing camera option.
If you cannot see the option for the camera, then clearly you don't have the correct hacked version of developer mode on your Star.
