Paul Grainger
I purchased a fiesta before Xmas to use through the winter months. The CLK, of course, had pole position in my garage.
After approx one month of non-use, I decided to take the CLK out for a spin. It was a nice day, and I was sick of the fiesta.
When I tried the CLK, the battery was completely dead. I mean COMPLETELY dead. My test meter showed zero volts across the battery terminals. Somewhat suprised, I attempted to recharge the battery (fat chance) but not surprisingly it was completely useless (three years old).
After recovering from the shock of purchasing a new battery, I decided to trace the 'fault' that flattened the battery.
With ignition off, all doors closed etc, my test meter showed a steady 330mA current drain. The battery was (originally) 100 Ah - the maths is simple - no surprise that the battery was flat after a month.
I decided to pull the fuses one-by-one to find out which circuit was drawing current - perhaps not surprisingly when I pulled the radio circuit fuse the current fell to only 30mA. I have retrofitted Comand, TV, multi cd, & DVD player all on this supply so I suspected that the problem resulted from something that I had done.
However, a series of tests revealed quite a surprise. With the nav CD inserted, the current draw with 'everything off' is 330mA. Remove the nav CD - the current draw falls to only 30mA.
I was - as you might expect - slightly surprised. So I repeated the test on another car (work colleague with OEM installed Comand). Exactly the same results.
Has anyone else experienced this?
There is a lesson to be learned here. I have always left my nav CD inserted - I won't in future. It's not a problem if you are using the car regularly - but could be if you leave your car for a couple of weeks at an airport etc.
Comand users be advised!
Paul G
Paul G
