comand cd/dvd
Steve Gaskin
Derby UK
CLS cgi
My comand system won't eject cd's. The mechanism can be heard but no cd appears. Also I have music on a 2gb SD card and that will not play. The radio works perfectly as does the Satnav. Car is a 2009 cls cgi.
Any help will be much appreciated or if anyone knows who repairs them in and around the Midlands.
Steve Gaskin said:
My comand system won't eject cd's. The mechanism can be heard but no cd appears. Also I have music on a 2gb SD card and that will not play. The radio works perfectly as does the Satnav. Car is a 2009 cls cgi. Any help will be much appreciated or if anyone knows who repairs them in and around the Midlands.
What cd is in there as it might be best if you left it in there ?!
It's a standard cd. Not a dodgy copy. The cd will not play or eject. When I press to eject it, comand aps makes all the right noises but then stops before disc is ejected.
Depending on the Comand version the whole mechanism can be changed.
Don't know anyone up your part of the UK that does repairs though :(
Same exact issue - How did you solve it?
Everything work (SAT/Radio/AUX) except the CD which doesn't do anything and when eject is pressed, it tries to eject but nothing afterwards.
It all started when the battery died and changed the battery.
What solution did you use? Thanks.
