Comand Online
seven
Wiltshire
Transporter Kombi
I would have pm'd but i cant as i dont have enough posts [says i have only made 8 but i am sure its more than that].
Anyway,i have a 2007 e320 with no phone kit and would like one.My technical expertise extends to answering email and switching on the tv so i would need it fitted [i am in Wiltshire so could come to you].
Perhaps you would be kind enough to let me know what we are looking at.
Many thanks.
You need phone pre-wire and if you have it you will have the UHI exchangeable cradle connector in the armest. You can use any of the cradles on the page below.
Comand Online Ltd :: Mercedes Phone/Bluetooth :: Cradles & Bluetooth Adapters
UHI connector: http://www.comandonline.co.uk/images/D/ML_HFP_connector_384-01.jpg
If you dont have phone pre-wire it can be retrofitted but it isnt cheap. The official retrofit will still require a cradle. http://www.comandonline.co.uk/Mercedes-Phone-retrofit-kit-MOST-based-cars.html
Or there is an aftermarket option the Fiscon Pro kit which works out cheaper and works exactly the same as MB phone pre-wire but wont require a cradle. http://www.comandonline.co.uk/Fiscon-Pro-Mercedes.html
Other option if you dont have pre-wire is upgrade to the MY09> Audio 20 unit. It has full bluetooth built in so no cradle needed.
