Comand removal procedure - help please
quasarman
Manchester
C320 Avantgarde SE Estate
Hi all
Can anyone let me know where to find the guide to removing the comand unit from an '02 c-class please. Ie taking the console apart etc as I need to get it out to give it a clean up (cd sticking/not reading).
I've been looking for ages but can't seem to find it :crazy:
Hi all
Remove gear lever surround.
Prise up wood/ali gear lever surround.
Remove ashtray (two clips at the front.
Underneath there are either two clips or two Torx 20 screws holding in the traim. Remove / unclip these.
Trim then prises off easily revealing the comand units four screws.
Easy - 5 minutes ;)
As Alfie says but I think you will also need to remove the center air vents.
There are two torx screws holding it in place.
Yep, procedure is the same as that for the facelifted car.
