Coolant colour change
Bucklebury
CLK 320 2005 for fun C220 cdi Estate 2013 for social and domestic
My indie will only use Merc parts for every thing and says that the blue coolant originally fitted to my 2005 CLK320 is no longer available following a water pump changeout.
So after 2x plain water flushes has now fitted Merc red coolant.
Should I be concerned or is this OK?
Yes the blue coolant has been discontinued. Thanks for the heads up about the red coolant as an option I didn’t know that .
Is the red coolant 15 year life as well ?
I use Fricofrin DP and they have changed the colour. I was doing the thermostat and auxiliary water pump, when I tried to order a litre of coolant for topping up the colour had changed. Same spec just different colour.
I can't say for all but our one (MB) with red coolant has a 10-year change schedule, the older blue/green one is 15-years.
What is the difference between factory fill and a subsequent change? It's the same fluid so should be another 15 years?
"Mercedes-Benz adopted an ingenious and
unique answer to this problem that allowed
the15-year/150,000-mile change interval to be
recommended starting in 2002: a packet of
silicate gel built into the coolant overflow tank.
Somewhat similar to the little envelopes of silica
that are used in the packaging of various products
as a desiccant, it serves as means of continuous
rejuvenation of the corrosion-protection qualities
of the antifreeze. Laboratory tests have shown
that even up to 15 years, most of the inhibitor
remains in the gel, still available to add protection."
