Sorry, I'm not sure of the best source of data for your engine - for my W124, I use the data available from MBUSA.
>>would it not come up as a fault
No, because electrically, it would still look OK to the ECU.
>>how do you know if it has been installed correctly
If the knock sensor were installed incorrectly, the ECU would not detect knock when it happened, until the intensity of the knock increased to a level higher than normal. Knock can be an engine damaging process, and so, if this were my car, I would want to be sure that I had followed the installation/torquing spec to the letter.
